amp sugestions needed
It's a little suboptimal that you have two 4ohm subwoofers if you will be bridging 2 channels to power them. In bridged mode, most amplifiers are only 4ohm stable, but two 4ohm subwoofers can be wired for either 2ohm or 8 ohm. When wired for 8ohm, they will get less power than the amp is capable of. But then again, 100-140watts a piece may not be too bad.
I'd recommend PPI P900.4 or its Soundstream TN4.900D clone, as the give you about 150watts at 4ohm on each channel, so the price/performance is great. I'd be curious to know if these amplifiers would sound any better or worse than the Soundstream rub series above.
parasite
parasite
Statesville, NC
zako
