Sold Amp sale, Crunch GP3000 and others
Ed Lester
SPL and Lights
BNIB Crunch GP3000D
cosmetic = 10/10
operation = 10/10
rated 3000w x 1 @ 1ohm/ actual = 4600w @ 1ohm on 16v, 4000w x 1 @1ohm on 14v
$500.00 shipped
Also
MTX 81000D Modded, used
cosmetic = 9.5/10
operation = 5/10
Amp powers up and plays but output is distorted, not sure of the problem.
$100.00 shipped OBO
Also
circa1998 Rockford Fosgate Punch 360.6
60w x 6ch amp.
Amp has never been used, vintage top of the line full range amp from 1998. Birth certificate says 78w per channel @2ohms
cosmetic = 10/10
operation = 10/10
$250.00 shipped
Also, Crunch PZI1500D
750w x 1 @1ohm RMS
operation = 10/10
cosmetic = 9/10, few nicks in the corners
$150.00 shipped
Also
Crunch PZI1500D
same as above except not working
cosmetic = 10/10
operation = 1/10, unit lights up but will not turn on
$50 shipped
Also
Cadence Ultra drive 400 2ch amp
I have 2 of these. 50w x 2 RMS at 4ohms, 100w x 2 at 2 ohms.
Work perfect
Costmetic = 6/10 Scratches and rusted screws
Operation = 10/10
$50.00 ea shipped
Also
MA Audio HK1998
1200w x 1 @1ohm
cosmetic = 9.5/10
operation - 2/10
Unit will power on and throws direct DC to speakers. Will damage speakers if hooked up in this condition, needs to be serviced
$50.00 shipped
Also
MTX Road Thunder 2600
300w x 2 at 2 ohms.
I actually measured this at over 900w x 1 at 4 ohms
Cosmetic = 8.5/10, one nick in corner
Operation = 5/10, Only left channel works. Right channel will throw direct DC at speaker and cause damage to speaker
$50.00 shipped
Also
MTX LSX 1 2 way electronic crossover
Never been used. was opened for the first time ever to take these pics.
$30.00 shipped
Or make an offer on the whole bundle. Maybe $1000.00 will take it all (shipping not included in that)
I do have many more pics
Any proof of the bold?
Here are some results that a fellow Team Maxxsonics member posted. This is from Team Livewire Eric.
quote from Termpro
Ok guys, here it is. Depending on your battery set up this amp will make an ungodly amount of power. With a 12volt battery set up dropping to 11.5 volts the Crunch GP3000D Pro made 2850 watts at a 1.03 ohm reactive. That's 4 12volt batteries. If you can get the voltage up the amp will make much more. By just starting the car and using the high amp alternator (starting at 16.1 volts and dropping to 12.3volts), the 3000 made 3732 watts. That's crazy isn't it. THAT'S NOTHING! I hooked it up to a 16volt battery set up and it just went crazy! With the battery voltage dropping to 15.7 volts with a 1.4 ohm reactive this monster made 4640 usable watts. NOW WHAT DO YOU THINK ABOUT THAT!
In my own tests I used a .95 ohm reactive load. and with voltage starting at 14.5 and dropping to 13.5v DC I measured 4050 watts.
These are all true RMS numbers.
I do not have any videos of the tests if thats what you are asking.
But if you search for info or ask any body else that has used or tested these, they will have similar numbers.
BTW, I just realized that I wrote the wrong date on the paper.
I got paid yesterday so I thought yesterday was the 30th. Forgot it was a holiday weekend.
Ed Lester
SPL and Lights
Ed Lester
Philly Pa
1rockford1
