Amp reading 7.6 volts...
if you are seeing 7 sumthin volts at the amp power wire back track go to the under hood battery see what ya got if you are at 13.8 or so you know you have a cut power wire or most prolly a jacked up fuse block. there should be no reason a solid copper wire has any difference in voltage from the batt or alt.....start there
---------- Post added at 09:39 AM ---------- Previous post was at 09:38 AM ----------
Knew it!
good job homme
SirTesticlies
SirTesticlies
alabama
bumpasauras
