amp ratings
whats the deal with people saying amps are over/underrated.
do the math and figure out the real number
volts x amps = total watts
a 20 amp fuse will not power a 1000w amp. please stop lying to yourselves
A lot of the more powerful amps are not fused internally.
so at 12.9 volts (way lower than what i'm seeing, normally 14.2-14.5) X's 40 amps (2x's 20 amp fuses) i'll see 516w from my mrp m450??? is there more to the equation like efficiency percentage.......lets just say my mrp m450 is 75% efficient............ take 516 X's .75 =387.......
ok now lets go back...........14.4 (normal volts) x's 40 amps = 576 x's .75 (efficiency %) = 432
this seems closer to true watts than before.
edit: alpine website says 80% efficient.
so........576 x .8 = 460.8
not bad i guess.
so on my helix that had 4x25 A fuses id have an output of 1.4 kW??? thats horse shit, theres a lot of it based into stabilitly and enabling the amp to work easier...
btw my helix had measeured output 320(rated 350)@4 and 480(rated 600) @ 2 ohms
and what to say about my rf bd 1000.1 then?
wait. shit. i didnt know the fuses power the amps...
why the **** do I even use batteries or an alternator... i should just pop a fuse on my engine and it'll power it right up...wait. why even have a ****ing engine, just stick a fuse on an electric motor and im good to go. I love earth so much.
what's the motivation for this rant? you mad cause someone won't buy an amp of yours?
isee people say "oh my mtx is underated cause it pounds". it cant draw more current then the fuses allow. bottom line
4*25=100 amps
100*14.4=1440 total possible watts
this is at 1 ohm. you limit power with higher resistance thats why its lower output at 2 ohms.
4*25=100 amps
so ure saying my amp had a kw jump at 1 ohm???sry, it was measured 700 smthg at one ohm, and it wasnt declared that low...and the measured output was at 14+v and its rated at 13.8:wow:
mdillon
ummm......what?
mdillon
visalia
mybird_91
