amp powers up but sub doesnt play
camry_tuner
i recently got a used rf 501bd. i hooked it up and it powered up, but the sub doesnt play. i double checked all the wiring, and it seems fine. if anyone is in the irvine area and wants to help me out in person, pm me. if anyone has any idea what's wrong, please help, thanks a lot
the sub is a jl 12w3v2, headunit is pioneer deh-p7500mp
edit: the sub was vibrating a little bit wen i powered it up, but there was no movement other than the slight vibration
the seller said its in working condition, and i double chcked all wiring and rca's like twice. the guy said he would give me a refund if it didnt work though, so we'll see if i could figure out what's wrong.
make sure the sub is turned ON on the pioneer... other than that check for 12v on remote... 12v on battery... make sure it's grounded fine... and meter the sub at the amp with the amp off and see what it reads
put a DMM to the + and - of the amp and see what it reads with the car on and music playing
Measure the remote and power w/ respect to ground ofcourse //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif. Also check the output (speaker channel)and see if what its reading there.
how do i check the fuses? i dont know how to open up the amp, for some reason i dont have the right allan's wrench size to open it up from the bottom...
edit: found the right one to open it. now i dont see the fuse x_X, also everything looks fine..
camry_tuner
camry_tuner
Los Angeles, CA
Slody4Futbol
