Amp just turned off
Dang bro I would have at least opened it up and looked for myself to double-check my own ideas. At least if it looked ok you could have closed a couple more scenario
I did open it up looked at top and bottom of board i couldnt fimd ****
Disregard then. And good luck on getting everything worked out. I've gotta pull my front door amp today and figure out why my left side cut out. It has played fine up until this AM. Hoping it's not something to cause me to need to pull out all the speaker wiring or RCA's.
i know i run all my wiring underneath my carpet so its a pain... also hopefully its just a bad rca ground or something thats what went on my mid/high amp
Mine's a Kicker ZR600. Come to find out it was the X-over Module had come out just enough from the dock that it wasn't cutting out on the left side, it was just barely playing and inaudible while the right played. So that eliminated wiring, over to amp, and presto. Now I've gotta get a piece of fine grit sandpaper and make sure all those connections aren't too dirty.
Loudmp5
skyhigh&banginlow
Loudmp5
florence az
Loudmp5
