Ok, here's my setup, pretty simple: 2 alpine amps: mrv-300 and mrv-1000, a 1F cap, 4 speakers, a sub and an HU. it's setup like in the diagram (attached)
my car battery dies within ~8hours when the car is off. on the mrv-1000 i notice the power light is like half on with car off - it also has the cap attached to it. (not the case with the mrv-300) The remote wire works - i installed a switch and sound cuts out when i hit it.
today i disconnected the cap and routed power directly to the amp (seems to run fine without it - last car couldn't handle the power, needed it). that half-light remains...i originally thought cause the cap held power, it was giving a little to the amp...i was wrong. the mrv-1000 seems to be the culprit. I've checked the remote/power wires and they are hooked up correctly. pulling the remote wire out of the amp does nothing - the half-light remains... it's only when power from the battery is cut (at the fuse for instance) that the light goes out.
Any ideas?!? I'm out...//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
(pioneer 480mp, alpine mrv-300, alpine mrv-1000, 1F lightning audio cap, 2way-infinity 6x9's, 2way-infinity 6x8's, 15"sony xplod sub) (4ga to the trunk, 8ga from dist blocks to amps/cap)(12ga-speaker wire all around)
