22mountaineer
6 /\
Long time no see (old guys), hello (new guys). Have an issue, not going to make any excuses, bottom line, I dont have a way to further test it and this is all I could come up with with the time at hand. If I need to look more I can try, but even doing this was pretty difficult (finding someone with the equipment). Basically nothing will come out unless I use the Green Circled Jacks. The speaker side is not labeled, however, in case it is relevant they were plugged into the left side. And the (L Input) RCA is the common point to get it to work. As far as equipment used to test, don't know much about it, I know he started having issues with his amp going into protect a few minutes after it was playing though. Tells me its all good, his amp is just overheating, could be wrong though.
A pic is worth a thousand words, you can barely see the lines but they are (green) horizontal and diagonal (red) vertical. Inputs on left, outputs on right. Circle on right is where I had the speakers hooked up. When the RCA's were hooked up in the green circle jacks, everything worked, not as loud as I would expect, but they worked. Obviously, red circles, didnt work like it should.
Any thoughts, if so, why(personal gain)? Thanks a ton
