If the speaker you are trying to hook up is dual voice coil then just bridge the four channels into two and hook them up as you would normally....If it is not dual voice coil then I think that the only way for it to be hook up is to use two of the four channels for the speaker and not use the other two channels at all unless they are hooked up to something else...
Adam
