factory speakers or a component set,coaxials?Is an amp needed for door speakers?
it would send alot more power to the speakers, which would make them sound alot better, and be louder. i would suggest having an amplifier porfessionally installed if you arent sure how to do itwhat would it be used for and how do you hook up 4 speakers to it?
What kind of car and year? How did you determine that those speakers are the right size? If you are running 4 speakers you will need a 4 channel amp. The C6882ie speakers are 4 ohm and are rated 60 watts RMS so you want to get an amp rated at least 60 watts RMS x 4 @ 4ohm (80+ recommended). What is your budget for amp? Realize that you will also have to get wiring which can add up fast as well.What kinda amp would I need?
