Amp For 8 12's
  • 4
first off never mix sizes like 10's and 12's, you will need a large mono block amp that is stable down to like 2 or 1 ohm.....are you competing db drag or anything if not than don't waste the money on lots of woofers 2 or 3 would be sufficient
get the visonik amps, mine is 1 ohm stable rms is 1000 watts, 1500 max, I could put four twelves in here, , but I only have two, which put me at 2 ohms, 750 rms, mono blocks are cool, especialy this one because it is parrell compatable, which means that I can get another visonik amp like mine and make then one huge mone block, which would be 2000 watts @ 1 ohm rms, 3000 peak., they only cost 500 a piece. I would do this If I wanted 8 12s in my car. ( dont buy crappy subs, kenwood is crappy, excelon ............might be good, but those tornados ****, get hollywood excrusions, thats what I have, and my systen is better than most. the amp even has a remote gain control, which is required with that kind of system.
6
132
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
313
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
309
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
368
chapy4650
chapy4650
cocoa, florida
A-hole
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
