amp for 2 12's DVC
  • 3
magplad95
12
NY
I have just recently bought 2 12inch alpine type r subs and i would like some advice on what amp would work best for these. The subs are DVC so i'm not sure what i need for them. I am planning on spending about 200 on the amp, assuming that the retail is about 400. I want the most bang for my buck here. I'm young and I don't have much experience with this stuff so any help would be greatly appreciated!
Originally posted by magplad95 I have just recently bought 2 12inch alpine type r subs and i would like some advice on what amp would work best for these. The subs are DVC so i'm not sure what i need for them. I am planning on spending about 200 on the amp, assuming that the retail is about 400. I want the most bang for my buck here. I'm young and I don't have much experience with this stuff so any help would be greatly appreciated!
JBL 600.1 You'll have about 400 more suggestions for this amp...
Originally posted by magplad95 4ohms each
You could probably get the JBL 600.1 still, but you would be running it at 1 ohm. Although it is stable at 1 ohm, you might be better off getting a high output 2 channel amp such as:
US Acoustics USX-2150: http://www.sounddomain.com/sku/USAUSX2150
US Acoustics USB-2150: http://www.crutchfield.com/cgi-bin/S-FD01DdC3zEH/ProdView.asp?s=0&c=3&g=110&I=235USB2150&o=m&a=0
which are both pretty much the same amp.
These are mearly a few suggestions. Look around at some other amps and then you can ask us if it satisfies your needs/is reliable/worth the money.
157
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
352
6
470
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
756
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
551
magplad95
magplad95
NY
tommyk90
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
