amp deciding not to work
broskin510
So Ive had these 2 kicker 12 inch L5's working GREAT for the last 3 monthes. then yesterday i went to the beach, everything was working perfect on the way there, then when im leaving, i realized my subs werent kickin. I thought maybe the amp was over heated or a fuse blew but i checked the car fuses n amp fuse n they were fine. My amp is being powered(the power button is on) just the LCD light ontop of the amp isnt glowing red, i ran a remote wire from the power on the amp to the remote on the amp and still no luck so i know theres nothing wrong with the remote wire or power , so im still yet to check the ground and relocate it to a different spot. I mean the amp power button comes on but the LCD lights on top of the amp that usually glow red arent coming on. Did my amp decide to give up ? It wouldnt have to do anything with my subs would it? any help is appreciated. thank you
Amp- Orion HCCA-D2400
As long as you wired it to the correct load, your subs shouldn't be the reason to why your amp doesn't work anymore. In cases like this, I like to disconnect the amp from the car and test it on a bench to make sure the amp is fully functional. If it is, then start looking at your wires. It does sound like a loose ground though.
broskin510
broskin510
Florida
osl
