jolly_26
Was having this discussion with a friend, and thought I'd post it up to see what you guys thought. It's not actually a problem I'm having or a situation that will occur in my setup or his.
Say for example I had a 1000 watt rms sub, and a choice of two amps, one that made 1000 watts rms, and one that made 2000 watts rms. Both amps are running at minimum impedance, and for arguments sake are identical except for power output.
With the 2000 watt rms amp hooked up and gained to 1000 watts rms, would it be less likely to clip during voltage drop than having the 1000 watt rms amp hooked up and gained to 1000 watts?
My theory was that it was far less likely to clip because it's only doing half rated, but my friend disagrees and says it's irrelevant. Am I correct in thinking this or not?
