Amp advice for a noob (07 Subaru Impreza WRX sedan)
agrogasboy
Noob to car audio.
If I intend to have component speakers up front (Focal VR or KR), then will run rears (stock speakers) off the HU (or will just disconnect), then a sub in the back (dunno what size). Just looking for better sound quality than the stock set-up.
What amp do I need? 4 channel amp or 5 channel amp? Recommended brands/models, given I just want a simple good sounding set-up?
I listen mostly to rock, and lounge/house music. Some bass would be good, but hearing the diff instruments and vocals is more essential to me. Car is an 07 Impreza which I intend to sound deaden (doors & trunk) with second skin.
I've been told the Alpine PDX5 is compact and good enough for my needs? Anybody with an opinion on that?
Appreciate your advice.
depends on your budget...and how much weight you wanna add to the car.
I already changed the stock HU last year to a Pioneer DVD unit. Looking to spend below $1000 for everything else, including sound deadening (just front doors & maybe trunk) & installation.
Again, if you are buying the stuff from a shop, most 5ch or high-powered 4ch amps are going to be around $500 by themselves. Components would be about $250 (don't get Focal; better stuff out there for less money), wiring at least $100, sub at least $150-250. That leaves no room for install and deadening. Search the Subaru and Impreza forums for audio installs and do it yourself!!
agrogasboy
agrogasboy
Philippines
LaserRed38
