amp 4 w713
mustangmoe
whats up guys i have a w7 13 with a ported box biult to specs i was looking for an amp that can give me the most power without blowing it.. Here are 3 amps
JL1000/11000 Watts RMS @ 1-4 Ohms
Built-In Electronic Crossover, Selectable 12/24dB
24dB Subsonic Filter
Built-In Parametric EQ
THD: S/N: >95dB at rated power
Frequency Response: 5 Hz - 250 Hz
Dampening Factor: >500@4 Ohms/50Hz
12dB Crossover
Earthquake phd5000w 5000 Watts x 1 Peak Power
3000 Watts RMS x 1 at 2 ohm
1500 Watts RMS x 1 at 4 ohm
Mono block - single channel amplifier
Damping Factor >800
THD: > 0.016
MA Audio hk4000d 4,000 WATT RMS DIGITAL MONO AMP
CLASS "X" (MORE EFFICIENT THAN CLASS "D" MONO
2000 RMS @ 4 Ohm
4000 RMS @ 2 Ohm
2 OHM STABLE
please let me know if i need a fared whats a good 1 for this setup sorry for asking so many ? i just dont want to buy junk
Welcome to the forum! First off, you don't need a fared (if you meant a capacitor) they serve no real purpose. Of the 3 listed I would choose them in this order:
MA
JL
Earthquake
I'm not sure what power requirements the W7 has though.
thanx this are the specs 4 the sub
Free Air Resonance (Fs): 23.5 Hz
Electrical “Q” (Qes): 0.476
Mechanical “Q” (Qms): 7.517
Total Speaker “Q” (Qts): 0.448
Equivalent Compliance (Vas): 3.68 cu. ft. / 104.3 liters
One-Way, Linear Excursion (Xmax)*: 1.25 in. / 32 mm
Reference Efficiency (no): 0.269%
Efficiency (1W/1m)**: 86.3 dB SPL
Effective Piston Area (Sd): 107.35 sq. in. / 0.0693 sq. m
DC Resistance (Re): 2.41 ohm***
Nominal Impedance (Znom): Dual 1.5 ohm
Thermal Power Handling (Pt): 1000W
Driver Displacement: 0.21 cu. ft. / 5.9 liters
Net Weight: 52 lbs. / 23.6 kg
mustangmoe
mustangmoe
staten island n.y
mustangmoe
