Am i safe......
pinoy2o9
i have 2 arc audio ks1000.1 and i just daisy chained them and now im at a final 2ohm load. but the thing is my subs are arc audio flatline dual 4. and they are pretty much wired down to 1ohm.
and i safe? or should i stop now?
its hooked up now and sound good. but im afraid i mite mess either the amps or subs up.
are the strapped or just daisy chained? sounds to me like you should prolly wire them individually to 2ohm, 1 per amp. if they are strapped the wire them to 4ohm not 1ohm. 1 ohm will smoke the amps as each amp will be seeing a .5ohm load
so if im going to run my subs pos to neg, to pos neg out each woofer im running 4ohm.
specs on the amp are 1100@1 1000@2 850@4
can u explain strapped?
what i see in the manual, what i did it said bridge.
pinoy2o9
pinoy2o9
Modesto, Ca
pinoy2o9
