alts for sale
mylows10
B2,singer,ampere rep
Item(s) for Sale: a newly rebuilt 12 volt customs 175 amp alt90 at idle and a powermaster 200 amp adjustable voltage 110 at idle
Item(s) Description/Condition: 175 newly rebuilt ,the powermaster 2 years old .both alts in perfect working order.wrecked the s10 on the 23rd and is totaled.kept the alts tho. the smaller alt was just completely rebuilt 2 days before wrecking my truck.new brushes ,stator,voltage reg,everything inside
Price: 175 amp 220 shipped and the powermaster 300 shipped
Shipping and Miscellaneous Item Information: usps 3 day priority
then you want the 200 amp, its 110 or 120 at idle and had adjustable voltage .its adjusted at 15 volts now ,which is where i ran my truck at.it has the square plug type , but you dont have to use the plug on this alt
im safe with 15 my stock alt is modded for 14.7 . does it have the same bolt placements
you are safe up to 15.2 volts and it does have the same blot pattern as the other one ,if you run both like i did ,your voltage will see the higher volts
no room for it since i have a v6. the alt is under the car with little room to spare. if i had the 4 cyl or did a system in my dads temp i wouldnt have a problem with both. send me a price to 24151 for it and if you can a model number so i can make sure. but my car runs a gm alt for stock so i assume it would fit
edit: had to change zip...still not used to it lol
mylows10
mylows10
monterey , ca
mylows10
