Alright, Here goes nothing.
Trepkos
Subwoofer box is in:
Subwoofers are in:
Amplifier is in:
AQ 2200d Amplifier
2x Fi Q DVC 1-Ohm Subwoofers
The box is sealed, dual chambered, around 1.5ft^3 per subwoofer after displacement.
The subwoofers are wired in Series and wired to the amplifier in Parallel to amount to a 1-Ohm load. I've double-checked the wiring, everything looks correct and perfect, the terminal knobs, interior box terminals, and wiring is all correct. I've also set the gains and whatnot on the amplifier with a DMM to both music and test tones so I am receiving the most power with as minimum clipping as possible.
I am by far the unluckiest soul in car audio by the way of Murphy's law but I have double checked, tripled check, everything has been checked in detail.
So here goes nothing. About to install the subwoofers back into their box and hook them and see how things go.
Wish me luck.
If you need luck then something is probably wrong..If you no its right its right //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Its right as right can be, but Ive learned in the past, that isn't always the best assurance.
Trepkos
Trepkos
Mississippi
Silver-N-Black
