Alright, Boys (Noob uncertainties)
[quote name='gckless']Natural roll off huh? Why that versus knowing where he's at?
And I wouldn't really trust those Polk's to get down to 63 under power :/ Not decently anyway.[/QUOTE]
so the comps at the lpf filter should be at 0db slope?! I didnt even catch that @gckless; thanks!
btw, I need to figure out what do with my doors to handle this back wave.. :/ that will wait till im not busy or summer
Actually, I've heard the crossovers on the Clarion were better, but Pioneer had the upper hand when it came to EQ. You might still be OK.
I've heard this too.
Btw OP, typically, you will want a 24dB/octave slope on your sub LPF and your mid HPF, and pretty much any slope between your mid and tweet. 12dB/octave and 18dB/octave are fairly common though.
[quote name='AxT4430']so the comps at the lpf filter should be at 0db slope?! I didnt even catch that @gckless; thanks!
btw, I need to figure out what do with my doors to handle this back wave.. :/ that will wait till im not busy or summer[/QUOTE]
0dB would be no slope at all, so if you did let your mids naturally roll off, then yes, they would have a LPF of 0dB/octave.
If your limited to certain amount of slopes or crossovers.. is it better to have more crossover points then slopes since there seems to be a fairly common amount of people using 12db/24db slopes?
Usually yes. But any processing that has a decent amount of crossover points will have at least 3 slopes. Combine that with a decent amount of crossover points and it should be enough to make a system work.
well, Im going to start my homework //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif thanks guys
before I get off completely, I only have 2 runs of rca's.. Sub rca to one amp and high's rca to highs amp.. with this new headunit will I need one more rca run for tweeters?
I'm sure this all make alot more sense as I get the headunit and start setting things up.. I can apply what I know and do some low volume testing with other variations
Meh I always thought the mobile monitors could actually handle a decent load on the woofer, it's just the tweeters that were the glaring issue with them. In that case, just run a LPF at 80Hz on the woofer, but I stand by the natural rolloff and it's not meant to be a permanent thing. It's more for him to figure out where his woofer starts to break up. It'll give him the chance to start dropping the tweeter HPF until the tweeter starts to stress and then he can lift that setpoint just a hair with the woofer matching it on a LPF, effectively band-passing the mid. Sorry if I'm confusing, but I'm exhausted.
Oh he's got the MM? I just assumed dB. Yeah, they should do alright then. And that makes sense. Sounds like you guys are taking care of biz on the sidelines? Not mad about it, you've got him on the right track.
AxT, Neo will take care of you. Just do your homework.
I think I follow! maybe not the methodology of bandpassing your way, but I know what bandpassing is, and what you probably mean!
Basically, I'm saying you want to continue listening to things a little out-of-normal until you can start to see the veil lifted on certain parts of the playable scale. Each time you make a change, something should definitely click in that things will sound noticeably better or worse.
Using a RTA can actually speed this process up because drivers that are playing overlapping frequencies will be visible by peaks in those areas around the crossover point. You should be making a goal of having the speakers play as flat as possible without even needing to reach for the EQ and then using your EQ to smooth out what your crossover points can't.
---------- Post added at 08:55 PM ---------- Previous post was at 08:54 PM ----------
No wait, i have db series.. polk db 6501, sadly..
OK then, stick somewhere around 80-100Hz on the HPF for the mids. IIRC, the only difference between the MM and the dB were in the woofer selection.
You mean eq as treble, midbass, .. yoda yoda //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif lol
Alright, I follow you! :0
Ill have to wait for RTA's although I agree.. using the software that KHA uses would be very handy
They're not very cheap for the standalone units, but they are extremely accurate. It'd make more sense to get one of those if you were a shop owner and would be doing RTA adjustments frequently. For now, just get one of the free apps for iPhone or Droid and use that on the 1/3 octave scale. That should be able to point you in the right direction.
Thanks! sorry for any //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif but I hope I made you //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Im feeling kind of //content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif//content.invisioncic.com/y282845/emoticons/flamer.gif.1fb8372af2de4b576aa9428ccc8a8f2f.gif lmao
Dude no worries. You're asking the right questions
AxT4430
AxT4430
Akron, OH
AxT4430
