Alright, Boys (Noob uncertainties)
AxT4430
So, my question I pose to you all is if I get an active headunit will it erase the need for a stand alone equalizer between my amp and headunit?
Also, what is a good deck to get for a newb coming into active units.
Also, do active drivers have cross overs or do they just wire to your amp?
Do I need active crossovers?
What are good active drivers ( 6.5 or 7"/8")
What are good active tweets?
[quote name='NASTY08IMPALA']if you have a active capable amp and you.re hu has a through setting on it then u dont need a new hu[/QUOTE]
Here is my setup ( passive):
Kenwood KDC HD552U ( not exact model, but similiar)
Polk DB 6501 6.5 component set ( passive cross overs)<----- ****
Aq 1200 amp
JBL Gto 1004
SPL 15"
---------- Post added at 04:33 PM ---------- Previous post was at 04:33 PM ----------
does have a through setting
@neo_styles;
[quote name='AxT4430']Here is my setup ( passive):
Aq 1200 amp
JBL Gto 1004
SPL 15"
@neo_styles;[/QUOTE]
not sire the specs on that amp but if it has full range freq adjustments for each channel then u wont need a new hu ..just remove the passive crossovers and set hu to thru then make adjustments on the amp ...its gona be tricky and time consuming to get set up the way u like
---------- Post added at 11:38 AM ---------- Previous post was at 11:38 AM ----------
Aq 1200 amp
JBL Gto 1004
SPL 15"
So, the flat setting- Select for full-range speakers when no subwoofer will be used in the system.
Would i want an equalizer or new headunit to tune my front stage?
ch[quote name='NASTY08IMPALA']yea that only has front and rear so u cant do active just off the amp...i know the 80prs is a popular active hu[/QUOTE]
Whats better a quality dedicated equalizer or an active headunit with eq and parameter settings/ eq bands?
@neo_styles; bitch get in here
Sorry for the delay. I prefer a HU with active crossover points since most will also let you adjust the slope. On the Eclipse I'm using now, I can go 6/12/18/24dB on the slope and the front stage will crossover down to 50Hz using passives. Haven't taken it to active mode yet, but I'm sure they cross more than high enough for the tweets.
As for drivers, really depends on the budget, but I really don't think you can beat the Dayton RS180 and RS textile dome tweets. Just need to fab something for the tweeters since they are large format. If that's a no-go, then Vifa makes a neo dome tweet that's pretty darn good and their VT25 is amazing as long as you keep it on axis
You could also keep whatever HU you're running and have an external processor like the JBL MS8 or Rockford 3.sixty. PPI even came out with a proc that's supposed to go head-to-head with the Rockford unit.
Well, the less Things in way of the speakers, the better. So if you can find an active HU, that has it's own adequate EQ, that'd be the best case scenario. Pioneer 80prs, Pioneer P99, Alpine 9887, Alpine 7998, Alpine 9813, Alpine 9855, Eclipse CD5030, Eclipse cd7100, Eclipse CD7200 Mkii.
There's no such thing as an "active driver". Every driver is a driver. The drivers you have right now would work fine, you just remove the passive crossover. The benefit of running active, is you can piece together your own component set if you'd like. So if you were to piece together your own set, you'd be looking at "raw" drivers. Drivers sold separately and individually. Parts Express: the #1 source for audio, video & speaker building components and Madisound Speaker Components: distributor of loudspeaker drivers and parts for speaker builders. are good places to look for these DIY speakers. Most decent tweeters starting at $20-$30 a piece. And mids usually around $50 to be safe. Some can be cheaper. Many can be MUCH more expensive. Keep in mind, you don't NEED new speakers. You can still use the ones you currently have, you just remove the passive crossover.
Active crossovers have nothing to do with the equalizer. Most do have a pretty decent EQ built in.
There isn't one, you need to understand slopes, and crossover settings and what drivers need what before you jump into that. Most active decks have generally the same settings, so it's not like one will be easier than the other.
"Active drivers" are just passive speakers. They have no crossover built in, that's what the active head unit is for.
Didn't you want to buy an "active" deck? Then why would you want active crossovers in addition to an active capable deck? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Far too many out there you'd have to try to find as many reviews as you can on drivers to see.
See above.
I've always heard good things about dayton as a company, so if those arent to expensive for my blood I will probably stick there. I do need new comps, my polks have been abused and either the tweeter or the driver on the passenger side is starting to fail and distort horribly..
AxT4430
AxT4430
Akron, OH
AxT4430
