Alright boys i ordered it.
Jacobman
CA
The Alpine PDX-2.150 with the Phoenix Gold RSd65cs speakers and $215 worth of wiring stuff off of knukoncepts. I got like 20feet of 1 guage and a distro block, 2 sets of RCS's and a bunch of other stuff, I only got 1 amp for now but i plan to put a sub in later so all ill have to do is plug and play. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Only question i have is my fuse sizes. 300amp for the 1guage after battery, and 2 150amps for the distro to the 2 amps. Will that be okay, i saw a chart that said you should use 250 for 1guage and 125 for 4 guage wire, so just checking.
I was looking at the wiring guide and it said 4guage 150amp fuse, idk. Will order different ones if needed.
I wonder if a local shop will have 125 and 250, they should. Dang now i have to spend more money, oh well. I got a few little install questions, 1) How do you mount the amp on your backseat, do you just drill it in? 2) How do you secure the crossover in your door? 3) Will RCA's being right next to eachother cause noise? Does not apply now but it will, i got these guys.
http://www.knukonceptz.com/productDetail.cfm?prodID=KARSS2.6M
1) Yup u can just screw it in
2) Again, just screw it down somewhere, or use zip ties
3) No, but keep them away from power wires and other electronics
1)what kind of car do you have? i know my civic is just foam behind the seat so "just screwing it in wont work"
2)i know my civic gets quite a bit of water inside the door at times so id suggest putting the crossovers in the trunk near the amps
3)like stated above keep away from remote and power wires.
Just so you know I am running a set of RSD's in my lexus with an ea4000 bridged sending them around 150w a door and the absolutely POUND. lol
Better than my cliffs and my cdt's.
Jacobman
Jacobman
CA
Rich00
