Sold alpine w200,12 disc changer,Alpine MRA-F350
pickup1
the w200 in pretty good shape with the ipod adaptor and tr7 bypass.got the box,sleeve,remote,the trim ring.no weak buttons or worn off lables.
$325 shipped and insured
Alpine MRA-F350,50 x 5 theatre amp,i have the box for it.
•5-channel Digital Theater amplifier
•50 watts RMS x 5 at 4 ohms
•Dolby Digital, DTS, and Dolby Pro Logic II processing built-in
•optical digital input (requires optical cable)
•all amplifier functions controlled by touchscreen of your compatible Alpine receiver (no built-in controls)
•connects to compatible Alpine navigation systems, including:
◦IVA-D100, IVA-D105, IVA-D106, IVA-D300, IVA-D310, IVA-D900, IVA-D901, IVA-W200, IVA-W203, IVA-W205, IVA-W505, DVA-9860, DVA-9861 and DVA-9965.
•MOSFET power supply
•CEA-2006 compliant
•Bass Engine® features:
◦variable center-channel high-pass crossover (20-400 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
◦variable front left and right high-pass crossovers (20-200 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
◦variable rear left and right high-pass crossovers (20-200 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
◦sub channel preamp output (20-200 Hz low-pass filter, 6, 12, 18, or 24 dB/octave)
◦variable subsonic filter (20-50 Hz in 1/6 octave steps, 6/12/18/24 dB per octave)
◦subwoofer phase control (0/180 degrees)
•time correction adjustment (0-20 mSec in 0.1 mSec increments)
•17-band parametric EQ (five bands for front, rear, and center, two bands for sub channel)
•STAR Topology (minimizes internal noise and prevents ground interference)
•detachable front cover
•blue power LED
•fuse rating: 20A x 2
$100 shipped and insured
alpine 1214 12 disc changer,not in the best shape,but i have another one that looks better,if you want to swap the cases.
got the long ai net cable and 1 set of brackets
$80 shipped for 1 or $100 for both.
will do all the above for 500 shipped and insured.
I have the XM stuff for it too, if that helps. And i can throw in an Orion Cobalt 265 amp ... that should cover it. Let me know
Or you can keep the changer(s), i doubt I'd use them anyways.
pickup1
pickup1
Polk City Fl
5SICK2
