alpine vs kicker vs hifonics, discussion about the 3
shayne1134
hey im starting this thread to ask a fairly simple question. at the moment i have 2 12" re xxx series subs dual 2 ohm coils, going to wire them to 2 ohm and put about 1500-1800 watts to each. i was going to get 4 alpine pdx1.1000 and turn the gain to 75% on all to get the 1500 watts i need, or i was thinking of getting a hifonics xxv goliath which is 3200 watts at 2 ohm split into 1600 a sub. or 2 kicker zx1500.1 amps, SO my question is, for the money, i expect to pay anywhere from 1000-2500, which is the better choice for my 2 subs?
the hifonics will do rated if you have an electrical system that can sustain 3200rms.
dont just set the gains to 75% though, you need to learn how to set gain properly, or else you will ruin your stuff
true but u talking about running 4 of those amps on what electrical if you got the juice by all means go ahead but my thing is voltage i said hifonics bc its only one amp well two internally but still its alot easier on the voltage and still does the same power
Kicker i think would be the best of these. good quality, and always make rated power. The pdx will make well over rated power as well i just dont really like the pdx amps due to there "noisiness"... other then that the Alpine is solid.
You should get a Kicker ZX2500.1, it is a solid amp and puts out good power @ 2 ohm.
I got mine for 500 along with a 4 chan amp
Edit: and dont turn your gains up to 75% just use DMM, the safest way.
shayne1134
shayne1134
Port Perry, Ontario
shayne1134
