Sold Alpine V12 Amps Old School "Cheap"
infamous_e46
hArRy_DaNgLeRs
Alpine mrv-1507 Alpine mrv-t407
Great Condition for the age
385 shipped conus for both or best offer
specs from alpine
Alpine Mrv 1507
Power Output: RMS Continuous Power (at 12.0V, 20 Hz to 20
kHz)
MRV-1507
Per channel into 4 ohms ......................... 150W, 0.08% THD
Per channel into 2 ohms .......................... 300W, 0.3% THD
Bridged into 4 ohms ................................ 600W, 0.3% THD
Power Output: RMS Continuous Power (at 14.4V, 20 Hz to 20
kHz)
MRV-1507
Per channel into 4 ohms ......................... 225W, 0.08% THD
Per channel into 2 ohms .......................... 450W, 0.3% THD
Bridged into 4 ohms ................................ 900W, 0.3% THD
Max. Power (at 14.4V)
MRV-1507
Per channel into 4 ohms ............................................ 450W
Bridged into 4 ohms ................................................ 1500W
Frequency Response ................... 10 Hz to 50 kHz (+0, –1 dB)
Signal-to-Noise Ratio
(referenced to rated power) ........................................ 105 dBA
Slew factor ........................................................ Greater than 5
Damping factor
MRV-1507/MRV-757 ................................ Greater than 500
MRV-F407 ................................................ Greater than 100
Input Sensitivity (for rated power
output) ........................ 200mV to 4.0V (1.0V at center detent)
Input Impedance ....................................... Line in: 10k ohms
Speaker Impedance ............................... 4 or 2 ohms (Stereo),
4 ohms (Bridged)
Active Dividing Network Frequency and Slope
MRV-1507/MRV-757 .......................... LP: 30 Hz to 200 Hz,
24 dB per octave (MONO)
HP: 30 Hz to 200 Hz, 12 dB per octave (STEREO)
MRV-F407 ............. 50 Hz to 400 Hz x 20, 12 dB per octave
Power Requirement .................. 11 – 16V DC Negative Ground
Dimensions (W x H x D)
MRV-1507 ............................... 260mm x 60mm x 530mm
(10-3/16" x 2-3/8" x 20-7/8")
MRV-T757 ............................... 260mm x 60mm x 330mm
(10-3/16" x 2-3/8" x 13")
MRV-F407 ............................... 260mm x 60mm x 330mm
Weight
MRV-1507 .......................................... 8.8 kg (19 lbs. 6 oz)
MRV-T757 ......................................... 5.2 kg (11 lbs. 7 oz)
MRV-F407 ........................................ 5.3 kg (11 lbs. 10 oz)
Alpine Mrv T407
kHz)
MRV-T407
Per channel into 4 ohms ........................... 40W, 0.08% THD
Per channel into 2 ohms ............................ 75W, 0.3% THD
Bridged into 4 ohms ................................ 150W, 0.3% THD
kHz)
MRV-T407
Per channel into 4 ohms ........................... 60W, 0.08% THD
Per channel into 2 ohms .......................... 100W, 0.3% THD
Bridged into 4 ohms ................................ 200W, 0.3% THD
MRV-T407
Per channel into 4 ohms ............................................ 140W
Bridged into 4 ohms .................................................. 400W
(referenced to rated power) ........................................ 100 dBA
Input Impedance ........................................ Line in: 10k ohms/
Speaker in: 15 ohms
4 ohms (Bridged)
Slope ....................................... 50 to 200 Hz, 12 dB per octave
MRV-F307, MRV-T707 .............. 260mm x 60mm x 270mm
(10-1/4" x 2-3/8" x 10-5/8")
MRV-F357 ................................ 260mm x 60mm x 400mm
(10-1/4" x 2-3/8" x 15-5/8")
MRV-T407 .............................. 260mm x 60mm x 180mm
(10-1/4" x 2-3/8" x 7-1/8")
Weight
MRV-F357 ......................................... 6.2 kg (13 lbs. 10 oz)
MRV-F307 ............................................. 4.3 kg (9 lbs. 7 oz)
MRV-T707 .......................................... 4.4 kg (9 lbs. 11 oz)
MRV-T407 ........................................... 3.0 kg (6 lbs. 9 oz)
Tried to pm you but it was full. I've got that earthquake d2,an earthquake d200hc, a fusion PP-AM20001 , a viper 400.2 , a small kenwood two channel , and probably some other **** that is slipping my mind at the moment. If you have interest in any of those amps how much cash would you want on top of one of them? What is your lowest cash price on that 1507? I'd prefer to keep this to PM if we could. Thanks
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
Spooney
