Sold alpine spx-177r ,Alpine MRA-F350 w/center ch.,ppi pcx 280
pickup1
only trades i might need is some long lengths or a spool of 12-16 gauge speaker wire,
a decent WORKING pc,just the tower or a laptop.
some sort of alpine eq.
or a decent pair of 12's or 1-15"
just got the alpines in,sound great,but i think i want to do the mb quart 3 way i have too.i traded a guy here from canada for the mounts,cups and hardware for the tweets,probably be here in a week or so.
they are 6.5" comps
asking 130 shipped.SOLD,SOLD,SOLD!!!!!!
alpine 50 x 5 theatre amp.5.1 surround,time correction,eq...included is the SBS-05DC.
150 shipped with the center ch speaker.no trim ring,sleeve with the center.will come with a long ai net cable.
•5-channel Digital Theater amplifier
•50 watts RMS x 5 at 4 ohms
•Dolby Digital, DTS, and Dolby Pro Logic II processing built-in
•optical digital input (requires optical cable)
•all amplifier functions controlled by touchscreen of your compatible Alpine receiver (no built-in controls)
•connects to compatible Alpine navigation systems, including:
◦IVA-D100, IVA-D105, IVA-D106, IVA-D300, IVA-D310, IVA-D900, IVA-D901, IVA-W200, IVA-W203, IVA-W205, IVA-W505, DVA-9860, DVA-9861 and DVA-9965.
•MOSFET power supply
•CEA-2006 compliant
•Bass Engine® features:
◦variable center-channel high-pass crossover (20-400 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
◦variable front left and right high-pass crossovers (20-200 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
◦variable rear left and right high-pass crossovers (20-200 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
◦sub channel preamp output (20-200 Hz low-pass filter, 6, 12, 18, or 24 dB/octave)
◦variable subsonic filter (20-50 Hz in 1/6 octave steps, 6/12/18/24 dB per octave)
◦subwoofer phase control (0/180 degrees)
•time correction adjustment (0-20 mSec in 0.1 mSec increments)
•17-band parametric EQ (five bands for front, rear, and center, two bands for sub channel)
•STAR Topology (minimizes internal noise and prevents ground interference)
•detachable front cover
•blue power LED
•fuse rating: 20A x 2
center specs..
•single-DIN car center channel speaker
•contains two 1-5/8" x 2" oval midbass drivers and a 1" soft-dome tweeter
•removable grille
•power range: 2-50 watts RMS (150 watts peak power)
•frequency response: 150-30,000 Hz
•sensitivity: 85 dB
•7-1/4"W x 1-15/16"H x 4-9/16"D
ppi pcx 280 with box and manual
80 x 2 @ 4 ohms
320 x 1 @ 4
excellant shape only 2 little smudges
120 shipped
heres some pics,will get some better ones in a bit.
specs on the alpines..
Technical Specification
Sensitivity: 87 dB
RMS Power Range : 75 Watts
Peak Power Handling: 300 Watts
Frequency response: 35-60000 Hz
Diameter: 6.5 Inch
Features
Cast Aluminum Frame
Optimized Airflow Dual-Flare Pole Vent
4 ohms Impedance
Angle Tweeter Mounting
2-way Crossover Ultra High Quality
Axis Compensation
26mm Soft Dome Tweeter
Bi-Wire Input and Selectable Tweeter Attenuation
Fiber Hemp Woofer Cone
Phase-Integrated Dustcap
Low Loss Rubber Surround
if anyone is interested in that type-x set, I just sent him all of the accesories, they're all brand new, so don't hesitate to buy them. I have the set, and for that price is almost makes me want to get another pair, they're great.
pickup1
pickup1
Polk City Fl
pickup1
