Alpine MRX-M100 No Sound From Amp
freeman187
Amp was working fine before building my new box. I removed my old box and sub from my truck and when I reinstalled it, the sub wasn’t getting any signal. I’ve tried switching RCAs and Power/Gnd cables. Fuses look good, internals look good, Redid the ground wire and still nothing. Light comes on and Power/Ground is at 12V. Any help would be great!(y)
Coul
Is there anyway the speaker wires may of touched a grounded part of vehicle before the box was finished if so they may of shorted something internal on the amp ...the newer Alpine amps have a lot of build quality problems I read about a new bad Alpine amp on here usually once or twice a week .
Had a PDX-M6 drop rail voltage out to my sub melting the cone and snapping the coil. I'm not a fan of the newer Alpine amps.
If you've measured input voltage then, disconnect the sub, move your Multimeter over to VAC, play a song and check to see if you have any output voltage on the speaker connection. Adjust gain back and forth and see if anything is registered. If not then unfortunately an internal failure and you can either repair it (if you feel you have the skills for it) or replace it. From my experience its not worth repairing though due to more and more failures being reported on their amps in the last 5 years.
Okay thanks for the info. And if it’s something internal then how exactly would I know to replace
You would need enough electronics knowledge to know how to test the internal components. Its not something that can be taught over a forum. You could also look into repair shops in your area to see if its worth sending in for repair.
Giving subs more power really wakes them up. The MRP-500 is pretty low power. You would really notice more authority in your bass.
657
my Alpine mrx-f65 in good condition, working perfectly well, and coming complete, local pickup only Thanks
  • Locked
COMPLETED Alpine MRX F65
hey mate, text me +1 (706) 300 5660 for quick response, i have a Alpine MRX F65 for sale at a secondhand price, stay safe
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
118
This weekend I will be taking actual pictures for other sites. So grab it before its gone
536
freeman187
freeman187
Aiken, SC
02WS6
    Apr 26, 2024
    Apr 26, 2024
