RajunCajun
I'm running 3-8 ohm w1 12s which gives 2.67 ohm load can the 5th channel handle this ohm load? Also I have a 4 channel Alpine MRV-F540.
If the F450 is not stable at 2.67 ohms can I bridge one channel on the F540 to power 1 sub and power the other 2 with the F450? or would this cause a sound problem?
Or would it be better to run all 3 off the F540 which is 2 ohm stable?
