5 channels, 2 for fronts, 2 for rears and a Sub channel
Amp has been tested and works perfect.
Price is $175 plus shipping. I will only charge exact shipping. Amp will be safely packed and insured sent via Fedex Ground
Or best offer.
SPECIFICATIONS
Power Output: RMS Continuous Power (at 14.4V, 20 Hz to 20kHz)
Per channel into 4 ohms (CH-1 – CH-4) ..... 50W, 0.08% THD
Per channel into 2 ohms (CH-1 – CH-4) ...... 60W, 0.3% THD
Bridged into 4 ohms (CH-1 – CH-4) .......... 120W, 0.3% THD
4 ohms (CH-5) ......................................... 150W, 0.3% THD
Max. Power (at 14.4V)
MRV-F357
Per channel into 4 ohms (CH-1 – CH-4) ........................ 90W
Bridged into 4 ohms (CH-1 – CH-4) ............................ 240W
4 ohms (CH-5) ........................................................... 300W
Frequency Response ................... 10 Hz to 50 kHz (+0, –1 dB)
Signal-to-Noise Ratio
(referenced to rated power) ........................................ 100 dBA
Slew factor ........................................................ Greater than 5
Input Sensitivity (for rated power
output) ........................ 200mV to 4.0V (1.0V at center detent)
Input Impedance ........................................ Line in: 10k ohms/
Speaker in: 15 ohms
Speaker Impedance ............................... 4 or 2 ohms (Stereo),
4 ohms (Bridged)
Active Dividing Network Frequency and
Slope ....................................... 50 to 200 Hz, 12 dB per octave
Power Requirement .................. 11 – 16V DC Negative Ground
Dimensions (W x H x D)
(10-1/4" x 2-3/8" x 15-5/8")
Weight 13 lbs. 10 oz
