alpine MRV-f352 powering aa assassin sub?
  • Thread starter sr_se-r
  • Replies 0
  • Views 7K
sr_se-r
Do you guys think the sub channel on an alpine MRV-f352 can power a single 10" AA assassin adequetly? And would that channel be able to run two ohms? Lets say 2 10" assassins? I currently have one on order and planned to just do a one amp setup because this car is just my beater. I've been reading the specs and all but im still fairly new to this car audio so maybe you guys could help me out!
specs are as follows
Specs on amp
RMS power (at 12V, 20Hz—20kHz)
30W x 4 (0.08% THD) into 4 ohms + 100W x 1 (0.3% THD) into 4 ohms
40W x 4 (0.3% THD) into 2 ohms + 100W x 1 (0.3% THD) into 4 ohms
80W x 2 (0.3% THD) into 4 ohms + 100W x 1 (0.3% THD) into 4 ohms
RMS Power (at 14.4V, 20Hz—20kHz)
50W x 4 (0.08% THD) into 4 ohms + 150W x 1 (0.3% THD) into 4 ohms
60W x 4 (0.3% THD) into 2 ohms + 150W x 1 (0.3% THD) into 4 ohms
120W x 2 (0.3% THD) into 4 ohms + 150W x 1 (0.3% THD) into 4 ohms
General
Frequency Response ................................................................ 10Hz—50kHz(+0,-1dB)
Signal to Noise (S/N) ............................................ 105 dBA (referenced to rated power)
Input Sensitivity (for rated power) ............................................................... 200mV to 4V
Slew Factor ......................................................................................... greater than 5
Input Impedance ......................................................................................... 10k ohms
Speaker Impedance .............................................. 4 or 2 ohms(stereo), 4 ohms (bridged)
Dividing Network ....................................Ch. 1—4 50Hz—200Hz HP/LP(12dB/octave)
................................................................ Ch. 5 50Hz—200Hz LP only(12dB/octave)
Power Requirements ...................................................... 11—16V DC (negative ground)
Heat Sink (WxHxD) ..................... 240mm x 53mm x 400mm (9-7/16"x2-1/16"x15-5/8")
Foot Print (WxHxD) ..................... 260mm x 53mm x 400mm (10-1/4"x2-1/16"x15-5/8")
Weight .................................................................................................... 5kg(11lb.)
sr_se-r
sr_se-r
madison, WI
sr_se-r
