Sold Alpine MRV-F345 4ch amp...$150 shipped!
LaserRed38
Started a new thread because everything else was sold...
Alpine MRV-F345
-4-channel car amplifier
-75 watts RMS x 4 at 4 ohms (150 watts RMS x 4 at 2 ohms)
-300 watts RMS x 1 (channels 3/4 only) in bridged mode
-Amp Link allows single cable connection for signal and control with compatible Alpine receivers
-2-, 3-, or 4-channel output
-CEA-2006 compliant
-Tri-way capable (Tri-Way crossover required)
-variable low- and high-pass digital filters, 30-400 Hz or 600-8000 Hz at 12 dB/octave
-bass boost (0-16 dB in 2 dB steps, centered at 45 Hz)
-MOSFET power supply
-STAR Topology (minimizes internal noise and prevents ground interference)
-preamp-level inputs and outputs
-oversized power and ground connections with gold-plated screw terminals
-top mounted controls with cover
-detachable front cover
-blue power LED
-requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
-dimensions: 13"W x 2-7/16"H x 9"D
Birthsheet shows 104w a channel!!
Pics:
Box is a little banged up:
Manual, warranty card and birthsheet:
Certificate:
Manual:
In the box:
Out the box:
Scratch on the front (barely noticeable after I waxed it):
Another little scuff:
That's all guys...thanks for looking.
-Patrick
LaserRed38
LaserRed38
Bay Area, CA
LaserRed38
