I have an alpine MRV 1507 Amp for sale along wiht a 1.0 Stinger capacitor, the stats are
Features:
General-Amplifiers
2/1 Channel Operation
Adjustable Crossover (HP/LP)
Auto High Temperature Protection
Auto Overcurrent Protection
Both sides Terminal Layout
Buffer Pre-Amp Output
Continuously Adjustable Gain Control
Cooling Fan
DC Straight Design
DC-DC PWM Power Supply
Direct Batt. Terminal
Discrete Pre-Amp Stage
Duo +- Feedback Circuit
Gold Plated Insert Power Terminals
Gold Plated Insert Speaker Terminals
Gold Plated RCA Input Connectors
High Damping Factor Circuit
Independent Power Supply Circuit
Input Mode Selector Switch
Large-sized Fuse
MOSFET Final Outputs
MOSFET Power Supply
MultiMode
Noise Elimination Coil
Parametric EQ (1-Band)
Phase Selector
STAR Circuitry
Solid Copper Bus Bars
Subsonic Filter
Top Mounted Multi Status Indicator
Top Panel Adj. of Parame.EQ/Gain/Crossover
Specs:
10% THD Power (at 14.4V)
Per channel into 4 ohms : 350W x 2
General-Amplifiers
Boost and Cut Range : +- 12dB
Dividing Network : 30Hz-200Hz HP(12dB/oct), LP(24dB/oct)
Equalizer Center Frequencies : 30Hz-200Hz
Foot Print (WxHxD)in : 22-7/8O x 11O x 2-3/8O
Foot Print (WxHxD)mm : 460mm x 280mm x 60mm
Frequency Reponse : 10Hz-50kHz (+0,-1dB)
Heat Sink (WxHxD)in : 22-7/8O x 10-1/4O x 2-3/8O
Heat Sink (WxHxD)mm : 460mm x 260mm x 60mm
Input Impedance : 10k ohm
Input Sensitivity (for rated power) : 200mV ~ 4.0V
Power Requirements : 14.4V DC (11V to 16V)
Q Factor (bandwidth) : 1.0-10.0
Signal to Noise (S/N) : 105dBA (referenced to rated power)
Slew Factor : greater than 5
Speaker Impedance : 4 or 2 ohms(stereo), 4 ohms(bridged)
Weight : 8.8kg(19lbs. 6oz.)
RMS Power (at 12V,20Hz-20kHz)
Bridged 4 ohms : 600W x 1 (0.3% THD)
Per channel into 2 ohms : 300W x 2 (0.3% THD)
Per channel into 4 ohms : 150W x 2 (0.08% THD)
RMS Power (at 14.4V,20Hz-20kHz)
Bridged 4 ohms : 900W x 1 (0.3% THD)
Per channel into 2 ohms : 450W x 2 (0.3% THD)
Per channel into 4 ohms : 225W x 2 (0.08% THD)
It says 900 watts but it pushes upwards of 1500 watts with the stiffening cap.
So whole package deal 325.00 without shipping included
If you are interested let me know.
Features:
General-Amplifiers
Cooling Fan
DC Straight Design
Large-sized Fuse
MOSFET Power Supply
MultiMode
Phase Selector
STAR Circuitry
Subsonic Filter
Specs:
General-Amplifiers
