Alpine ixa w404??
Hey dude,
I got one and had the same problem. After searching on the net i found the answer. You need to connect the yellow/blue wire to your handbrake switch cable and then your yellow/black wire to your foot pedal switch (might have to find out which one since there are a few)
These two cables should be heaps longer than the others.
Once they are connected. With your ignition on Accesorys or the car running. You need to do the following:
- Start with the handbrake disengaged and your foot off the brake pedal.
- Push down the foot brake pedal and hold it down
- Lift the handbrake
- Drop the handbrake (so the light on the dash turns off)
- Lift the handbrake again
- Let go of the foot brake
Now you should have all the setup options. What a pain in the a$$. Couldnt find anything in the manual either, had to google heaps and found it.
Good luck
Alex
Yea it really is a pain but the thing is that i have the foot and hand brake wires connected to the pac7
and i havent been able to find anything but alot of people seem to have this problem
robertq
robertq
Bay Area
robertq
