Alpine IVA-D310 and MRA-F355 Theater amp (built in baby PXA-H701)
SentraStyle
Alpine IVA-D310 AM/FM/DVD in dash flip out touchscreen and Alpine MRA-F355 5 channel theater amp with built in processor.
The in dash is in good condition (I'd give it a solid 8/10). It comes with all accessories needed to install (head unit, brain, mounting cage, trim ring, wire harness, DC/DC converter with power harness, cable that connects brain to main unit, and antenna extension cable. It is missing the remote and remote harness.
The amp is in fantastic condition and could pass as new. Amp is rated at 50 x 5 (Front L/R, Rear L/R, and center and has an RCA pass through for subwoofer amp. It comes with everything as new. You will need an optical cable to connect the amp to the head unit (any one will work as it does not use the proprietary cable the newer units use.
Amp Specifications
RMS Continuous Power (Watts) (at 14.4 V, 20-20 kHz)
Per channel into 4 ohms (0.08% THD+N): 50 W x 5
S/N Ratio (IHF A Weighted)
(Reference: rated power into 4 ohms): 100 dBA
CEA-2006 Power
RMS into 4 ohms at ≤1% THD+N: 50 W x 5
S/N Ratio (Reference: 1 watt into 4 ohms): 80 dBA
Input Impedance: 10 k ohms
Input Sensitivity (V/at 10 k ohms): 0.85 V (Ai-NET)
Frequency Response (+0, -1 dB): 20-20 kHz
Crossover Frequency
Front L/R (HP: ON/OFF): 20-200 Hz, 1/3 oct step, Slope: 6/12/18/24
Rear L/R (HP: ON/OFF): 20-200 Hz, 1/3 oct step, Slope: 6/12/18/24
Center (HP: ON/OFF): 20-400 Hz, 1/3 oct step, Slope: 6/12/18/24
Subwoofer Output
LP: ON/OFF: 20-200 Hz, 1/12 oct step, Slope: 6/12/18/24
Subsonic: ON/OFF: 20-50 Hz, 1/6 oct step, Slope: 6/12/18/24
Parametric EQ
Number of Bands: 17 (Front: 5, Rear: 5, Center: 5, Subwoofer: 2)
Frequency: 20-20 kHz (1/6 oct step)
Width (Q): 0.5/1/2/3/4/5
Level: ±9 dB
Time Correction
$400 + shipping
Ships via USPS
Item(s) for Sale:Alpine IVA-D310 AM/FM/DVD in dash flip out touchscreen and Alpine MRA-F355 5 channel theater amp with built in processor.
How much for everything except the amp
Amp Specifications
CEA-2006 Power
Crossover Frequency
Subwoofer Output
Parametric EQ
Level: ±9 dB
Time Correction
$400 + shipping
Ships via USPS
SentraStyle
SentraStyle
Kissimmee, Fl
SentraStyle
