Alpine Imprint Set-Up ( PXA-H100 with KTX-H100 tuning kit)
absavino
I have some questions about hooking up the imprint. The instructions are not all that clear.
My current setup is as follows:
- Alpine iDA-X305S HU
- 4 channel amp connected to components in the front and coaxials in the rear
- Mono amp connected to two subwoofers.
-Sirius SC-C1 tuner and Alpine KCA-SC100 Interface
-- The KCA-SC100 is connected to the HU through the AI-NEt connection.
-- The KCA-SC100 has an Ai-Net pass-through connection
Imprint: PXA-H100 with KTX-H100 tuning kit
Questions:
1. Can I connect the imprint to the KCA-SC100 AI-Net pass-through or does it have to be connected directly into the HU? The imprint has an AI-Net pass-through but from what I understand, only the cd changer should be connected into the imprint AI-NET pass-through.
2. Does the imprint have to always have a constant electrical connection (i.e. when the engine is off, there is still power) or can I have it connected so it only comes on when the radio is on?
3. Once I use the mic and software to get a curve, do I disconnect the imprint (i.e. the power and connections to the amps) or do I keep it connected. I guess I am confused if the sound will now go through the imprint to the amps or if I still need to run the sound from the rca's in back of the HU to the amps and thus disconnect the imprint's rca connection to the amps.
Thank you.
absavino
absavino
Dallas
absavino
