Sold Alpine HU and Changer for sale
rockinridgeline
Alpine TDM-7546 tape deck CD changer controller and CHM-S620 6 disc CD changer with 1BIT DAC 8 times oversampling (including Din cable to HU)
I'll only sell these two as a pair as the radio doesn't have much value without the changer. I have the box and packaging for the changer along with the mounting brackets. I just pulled these out of my 69 Mustang. These units have only seen about 3000 miles on the road since purchased new around 2000. I still have the original sales receipt for the changer.
$115 shipped for these two OBO
WILL ONLY SHIP TO VERIFIED PAYPAL ADDRESSES. PAYPAL IS ONLY METHOD OF PAYMENT.
I am new to caraudio.com but you can check my references at DIY mobile audio under the same username. I also have perfect feedback on ebay.
specs on the HU
TAPE PLAYER Tape Speed...........................17/8in./sec. (4.8cm/sec.)1.0%
Wow and Flutter.......................................................... 0.13%
Signal-to-Noise Ratio, Dolby B NR On/Off..........68/60db
Frequency Response (70ms Mental Tape).30-22kHz..(3db)
FM TUNER Tuning Range .................................................... 87.7-107.9 MHz
Mono usable sensitivity ................... 9.3dBf(0.8mV/75 ohms)
50dB Quieting sensitivity .............. 13.5dBf(1.3mV/75 ohms)
Alternate Channel Selectivity ........................................... 80dB
Signal -to-Noise Ratio ......................................................... 65dB
Stereo Separation ................................................................. 35dB
Capture Ratio ....................................................................... 2.0dB
AM TUNER Tuning Range ....................................................... 530-1,710 kHz
Usable Sensitivity ............................................. 22.5mV/27.0dB
POWER OUTPUT Maximum Power Output (Note 1) ................................ 35Wx4 Continuous Power Output (Note 2) .............................15Wx4 GENERAL
Pre-out Voltage (Vol. centered, into 10 kW) .............. 500mV
Pre-out Voltage (Maximum) ................................................. 2V
Bass Control Range ........................................... 15 dB at 30Hz
Treble Control Range ...................................... 10dB at 10kHz
Operating Temperature ........... 60°C (140°F) to -10°C (14°F)
Power Requirement .............. 11-16V DC (Negative ground)
Mounting Angle ............................... Within 30 of horizontal
Chassis (WxHxD) ........................................................... 7"x2"x6"
Nosepiece size (WxHxD) .................... 6-3/4x1-13/16x11/16
Weight ................................................................. 3lb.1 oz (1.4 kg)
rockinridgeline
rockinridgeline
Indiana
rockinridgeline
