Sold Alpine Expert Mrv F505 4 Channel Amp
  • Thread starter Latina33
  • Replies 0
  • Views 10K
Latina33
CA
This old school amp is in used but great used shape. It has NOT been refurbished or abused, and has all of the original plugs, terminals, and hardware. It is cosmetically and functionally in very nice shape. I will take $225.00 shipped in the continental U.S., and full insurance will be included in this cost. Please email or PM for pics. Thanks.
Here are the official specs for this amp:
General
4/3/2 Channel Operation
MOSFET Power Supply
DC-DC PWM Power Supply
No Current Limiting
Double Buffered Pre-Amp Input Circuitry
Discrete Pre-Amp Stage
MOSFET Final Outputs
DC Straight Design
STAR Circuitry
Duo ß Feedback Circuit
Solid Copper Bus Bars
Top Mounted LED Power Indicator
MultiMode™
Independently Adjustable Crossover (HP/
LP/BP Capability)
Top Panel Adjustment of Crossover and
Gain
4 Volt Straight Input Switch
Input Mode Selector Switch
Continuously Adjustable Gain Control
Gold Plated RCA Input Connectors
Extra Large Gold Plated Screw-Down
Power Terminals
Gold Plated Screw-Down Speaker
Terminals
Non-Fading Pre-Amp Output
RMS Power (at 12V, 20Hz—20kHz)
Per channel into 4 ohms ............................................................. 50W x 4 (0.08% THD)
Per channel into 2 ohms ............................................................... 65W x 4 (0.3% THD)
Bridged 4 ohms ....................................................................... 130W x 2 (0.3% THD)
RMS Power (at 14.4V, 20Hz—20kHz)
Per channel into 4 ohms ............................................................. 75W x 4 (0.08% THD)
Per channel into 2 ohms ............................................................. 100W x 4 (0.3% THD)
Bridged 4 ohms ....................................................................... 200W x 2 (0.3% THD)
General
Frequency Response ................................................................ 10Hz—50kHz(+0,-1dB)
Signal to Noise (S/N) ............................................ 105 dBA (referenced to rated power)
Input Sensitivity (for rated power) ............................................................... 200mV to 4V
Slew Factor ......................................................................................... greater than 5
Input Impedance ......................................................................................... 10k ohms
Speaker Impedance .............................................. 4 or 2 ohms(stereo), 4 ohms (bridged)
Dividing Network ................................. 50Hz—8000Hz HP/LP/Bandpass(12dB/octave)
Power Requirements ...................................................... 11—16V DC (negative ground)
Heat Sink (WxHxD) ..................... 240mm x 53mm x 400mm (9-7/16"x2-1/16"x15-3/4")
Foot Print (WxHxD) ..................... 260mm x 53mm x 400mm (10-1/4"x2-1/16"x15-3/4")
Weight .......................................................................................... 4.5kg(9lb. 14oz.)
Latina33
Latina33
CA
Latina33
