1. Product:
Alpine ERE-G190 Subwoofer Processor & Equalizer. This particular equalizer is getting rare, and harder to find every day. This is an electronic 2 way variable crossover, 1 band parametric equalizer and 3 band graphic equalizer with a subwoofer volume control.
2. Specs:
Features
Graphic-EQ Number of Bands 3 Bands
Graphic-EQ Boost/Cut Range +12 DB
Graphic-EQ Center Frequencies 500 Hz, 2 kHz, 8 kHz
Parametric-EQ Boost/Cut Range ±12 dB
Factor Q 1.0 – 10.0
Parametric-EQ Center Frequencies 30 Hz – 200 Hz
Frequency Response Front/Rear Output: 40 Hz – 50 kHz (+0, –1 dB)
Subwoofer Output: 10 Hz – 170 Hz (+0, –1 dB)
Signal-to-Noise Ratio 112 dBA
Crossover Frequency L.P.F.: 30 Hz – 200 Hz
H.P.F.: 30 Hz – 200 Hz
Crossover Slope LOW: –24 dB/oct.
HIGH: –12 dB/oct.
Subwoofer Level Control 0 dB – +15 dB
Input Impedance RCA Line Input: 10k ohms MIN.
Speaker Input: 30k ohms MIN.
Output Impedance 1k ohms MAX.
Dimensions
(W x H x D) 7" x 1" x 5-1/4"
Weight 1 lb. 7 oz
3. Description/Condition:
used but looks pretty nice for the year a little rust on bottom, top has a few scratches, face looks clean. i bought it off nik592 he said everything works like new. ive actually never used or even know how to use this, but for all i read it seems kind of top of the line! nik said there was something missing in the back but i dont think its something from the unit but something you need with the cd player.. the cables it has...
ground,battery,remote on.
input,rear output,sub w output,front output.
looks like it needs the SP input.
if i cant sell this i will probably just figure out how to use it and mount it because it looks pretty cool atleast ha
it does have some sort of illumination to it also..
1(260)517-3593
for any fast questions or anything text me.
4. Price: :
75$ obo trades of whatever offer up!:dontknow:
5. Pictures:
2. Specs:
Features
Factor Q 1.0 – 10.0
HIGH: –12 dB/oct.
Dimensions
Weight 1 lb. 7 oz
1(260)517-3593
4. Price: :
5. Pictures:
