Well,I did some searching..Thanks to the google sites..As follows at 11.6/12v:
3522- 2x30@4ohms
2x40@2ohms
1x80@4ohms bridged THD.3%-100Db
3540-2x30@4ohms
2x40@2ohms
1x80@4ohms bridged THD.3%-100Db-pretty much same as the 3522
Now this is a little B/A amp that ItsAJeepThing picked up from me
3523-2x40@4ohms
2x50@20hms
1x100@4ohms bridged THD.3%-110db
3513s-2x25@4ohms
2x35@2ohms
1x70@4ohms bridged THD.4%-105 db
KEEP IN MIND:these ratings are at the 12v specs,so your car now is usually at 13.4 up to 14v,so the wattage will be MORE! I know that the 3522 will push 2 sets of 6x9,and a pair of 150 rms 10s pretty decent as well as the 3540,the 3513s-I know it will push a pair of 6.5 -50rms speakers,5.25,2)sets of 50rms tweeters,and I put it on a 150rms 8in sub at one time,Now the 3523-Hmm-Now that amp has got some real power, i had it on a pair of kicker KS 6.5 and a pair of KS 25 tweeters,and a pair of 360rms ABC Audiobahn 3ways,and a pair of 1oorms Infinity tweeters,I have had it on a 600rms sub,2 150rms 10s,4 200rms 8s,2 sets of JBL GTQ 100rms 6x9 before.I wouldnt be,and i have as you have been told? to run these amps for front stage,or rear staging,and even a single 12/10 ect.Good amps,and fairly clean.I will test again before they go out to make certain they are working properly for you.I just have too many amps,and they really need to be used rather than sitting up.They were all around $120 and to like $190 for the 3523 in like 92,and still working great.If you need fresh pics let me know,and I will get them. I will place some here in a bit.Thanks,and hope this info helps out.Pm me ,or let me know here,I will be checking time to time...thanks:thankyou:
