Alpine CDE149,148,147BT AUDIO SETTINGS AND VOLTAGE GAINS
  • Thread starter Alrojoca
  • Replies 0
  • Views 773
Alrojoca
Defeat on can be used to set the gains, it sets everything to flat or off.
EQ user vanishes or can not be saved if any of the pre set EQ settings is used and everything has to be adjusted again
MX is basically loudness it has 3 levels
The level of Every source can be adjusted to keep volume levels even on all, the CD vol level is like 6 points higher than all others.
One touch audio settings gives the basic, sub level, treble, bass balance and fader, treble affects the level of band 8 on the EQ and bass affects the level on band 2.
Hold the audio button and you get all the xovers, slopes, etc, flat slope is xovers off, TA, Spatial, MX( loudness) levels for each source,
The PEQ has 3 settings per band, frequency, how wide you can make the band and level
Alrojoca
Alrojoca
USA West Coast
Alrojoca
