Alpine CDA-9887 Lighting
Alpine CDA-9887 Front $399.99 Add To Cart
General
Chassis Size Code IEJ
RMS Power Output 18 watts
Peak Output 50 watts
CEA Compliant Yes
RMS Power Bandwidth 20-20kHz
Preamp Outputs 3 pair
Sub Preamp Outputs Yes
Preamp Voltage 4 volts
Display Color White
Key Button Color Blue/Red/Green/Orange
I was afraid of that! Sounds like aminor step backward from an aesthetic viewpoint but as long as the SQ is good it'll be ok. I may simply run with my 9835 til it crashes and burns but I fear it is getting closer, and in truth I could really use bluetooth in my car.
it also does not have a motorized face. How do you know the 35 is dying?
A while back, the 4 buttons on front ( illuminated ones ) began to drop the blue color on occasion. The blue would go out and I'd be left with a combination of the red and green. This only happened a few times and after a day or so, the blue would return, no issue. Lately, it has begun doing this fairly often and only after removing the faceplate and resetting it several times does it go away. I cleaned all the contacts and thought it had been fixed it but it's happening more frequently.
2 days ago I turned my car on and the Sirius channels were totally locked. None of the buttons would work. After truning it back off, I discovered the regular tuner was fine as as the CD player, but the Sirius tuner display was going wild with the channels continuously scrolling ( even though it was locked onto a single channel ). Nothing worked. Then, magically, after several turning on and offs, it is working again.
I"m going to watch it for a couple more days but just seems it is getting ready to take a nose dive!
jdavis37
jdavis37
NC
jdavis37
