Sold Alpine / Autotek / OZ Audio / Maxx-Link / Delco
RidnClean
Love 4 Money
1. Product:
Alpine 7909
Alpine 6 Disc CD Changer
2. Specs:
Features:
Full Front DIN Chassis
CD Shuttle Controls
Quick Release Bracket
T-10 II Tuner
8-times oversampling digital filter
18-bit Dual D/A Converter
Compact disc Straight
Power loading/self loading
plays 3-inch disc w/o an adapter
music sensor
repeat, scan, random play
Eject Auto-Lock
digital clock
Dual Preamp Outputs
Litetouch 24-Station Presets
Preset Address
Local/distance Switch
Dimmer Lead
Autdio Mute Lead
High contrast flourescent Display
Specifications:
General:
Output voltage (Preamp) ~ 500mV
Bass Adjustment ~ +/- 18 dB @ 30 Hz
Treble Adjustment ~ +/- 15 dB @ 15 kHz
Dimensions ~W 7" x H 2" x D 6-1/8"
Compact Disc Player:
Samplying Freq ~ 352.8 kHz (8x Oversampling)
# of D/A Converters ~ 2
# of Quantization Bits ~16-Bit Linear System
Freq. Response ~ 5 Hz - 20 kHz
Wow & Flutter ~ below measurable limits
THD ~ 0.002% @ 1 kHz
Dynamic Range ~ 100 dB
SNR ~ 110 dBA
Channel Separation ~ 95 dB @ 1 kHz
AM Tuner:
Sensitivity ~ 10 uV
FM Tuner:
Mono usable sensitivity ~ 16.3 dBf (1.8 uV/75 ohm)
50 dB Quiet Sensitivity ~ 20.7 dBf (3.0 uV / 75 ohm)
alternater channel selectivity ~ 80 dB
SNR ~ 60 dB
Stereo Separation ~ 35 dB
Capture Radio ~ 2.0 dB
AM suppression ~ 45 dB
3. Description/Condition:
good condition
minor scatches
will clean up some before i ship
***IT DOES NOT INCLUDE THE NOISE FILTER IN THE HARNESS***
4. Price: :
$650shipped SOLD
5. Pictures:
1. Product:
Autotek MM100.4
2. Specs:
4 X 100 Watts RMS into 4 Ohm
4 x 150 Watts RMS into 2 Ohm
2 X 300 Watts RMS into 4 Ohm
goood
4. Price: :
$150shipped SOLD
5. Pictures:
1. Product:Autotek MM75.4
2. Specs:
4 X 75 Watts RMS into 4 Ohm
4 x 125 Watts RMS into 2 Ohm Mono
2 X 250 Watts RMS into 4 Ohm Mono
3. Description/Condition: good
4. Price: $130shipped SOLD
5. Pictures:
1. Product:
Custom Power OZ 18
2. Specs:
OZ 4" motor with spaced 6 spoke bakset w/gasket
4" D1 4 layer Alum flatwound coil with vented former
tripple sewn leads
direct connects
paper cone
black poly dome.
4K RMS
Brand new
4. Price: :
$450 + shipping
5. Pictures:
1. Product:
Maxxlink MLX-100
2. Specs:
MaxxSonics Universal Amplifier Bridging Interface with a Synchronization Module
Permits interconnecting and linking mobile amplifiers into a master and slave configuration
Link up to five amplifiers max
Remote level control with LED clipping indicator
Master and slave control switch
Built-in setup tone
24dB Adjustable low-pass filter (35-250 Hz)
24dB Adjustable subsonic filter (15-35 Hz)
10dB Adjustable parametric bass EQ
Variable wide and narrow bandwidth control
0-180 degree Adjustable phase control
2 Channel RCA audio pass-thru
Dimensions: 6"L x 8-7/8"W x 1-1/2"H
super minty
4. Price: :
$75shipped SOLD
5. Pictures:
got 169 left.
i'll sell the whole box for 60shipped
specs:
Power Handling: 20 watts RMS/40 watts max *VC dia: 3/8" *Znom: 6 ohms Re: 4.10 ohms *Frequency range: 6,000-20,000 Hz *Fs: 4,200 Hz *SPL: 87 dB 2.83V/1m *Driver Dimensions: Overall Diameter: 1-3/8", Cutout Diameter: 1-1/4", Mounting Depth: 5/8".
RidnClean
Love 4 Money
RidnClean
Washington
RidnClean
