looking for help with an AM reception issue
I have 2003 silverado w/ alpine h/u and 2 fosgate amps under back seat
FM reception is fine - so is CD - all clear sound with motor off or on
however, AM is very bad with feedback / howl / warble that rises and falls
it does this with the motor on or off
I have checked most of the grounds etc and the antenna - tried removing the whip etc.
I also disconnected the 100amp fuse to the amps and the sound is still there from the fronts...
I am considering
- checking with a separate battery?
- testing for any and all ground loops?
- I tried removing many of the fuses one at a time to see if it stops - no luck
also, and this may be a contributing factor...
when I use the power windows on the passenger side, there is a loud raspy noise
in the system - BUT not when the dirver's side power ones are used....
any sugguestions?
please help
thank you,
john
I am considering
any sugguestions?
please help
thank you,
john
