Alpine 9835 FM Tuner Reception
  • 1
I just got a new system installed today. Alpine 9835 head unit (HU). MB Quart Reference 5.25" Components, JL Audio 4300 4 Channel Amp, and JL Audio 10" sub. It sounds great. The head unit is ridiculous! I love it. One weird problem...the FM reception (do not get any stations on AM signal). I live in Los Angeles, and have previously owned low-end Sony HU's and never had any problem tuning my favorite stations (everything alweays came in clear, no intereference). This unit is different: when set to auto DX tuning, it only tunes 4 stations, the rest have to be done manually (and even when tuned manually I get continual hits of of intereference)...weird, huh. In local mode, it doesn't tune any stations automatically. Every station I listen to must be tuned manually (which I never I had to do before with my $100 Sony CD HU's). I had it professioanlly installed at my local Al & Ed's. I am going in tomorrow to let them know the problem tomorrow but I want to be armed with a little bit of knowledge. First, is it possible that the HU's antenna is faulty? or possibley something else in the HU that could be damaged that is causing poor reception? or is it perhaps an installation problem in that perhaps the antenna is rubbing against something that is causing interference? or that the antenna is not properly installed? Any other ideas that could be causing this problem? Last point: the HU has a setting that has "Stable, Normal, and Hi-Fi." The manual says that if you are not getting desired reception at Hi-Fi (best quality setting) try "normal" and "stable." I have tried all settings to no avail. Any ideas would be greatly appreciated.
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
242
This weekend I will be taking actual pictures for other sites. So grab it before its gone
6
660
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
ultraviolet353
ultraviolet353
Los Angeles
ultraviolet353
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
