Alpine 10" Type R For 8" Sub
dross93ranger
1. Product:
Alpine SWR-1043D
2. Specs:
10" Dual 4 ohm Type R Subwoofer
Power Handling:
Peak: 1800 watts
RMS: 300-600 watts
Kevlar reinforced pulp cone woofer
2-Piece Structural Parabolic diaphragm design
Injection molded Santoprene rubber surround
Alpine exclusive High Amplitude Multi-Roll (H.A.M.R) surround for impressive excursion and clean, accurate bass
FEA Optimized progressive NOMEX spider
Radial vented VC head sink
Concealed mount gasket system
Reinforced layer spider integration tinsel leads
Oversized 2-1/2" Voice coil
4-Layer dual voice coil design
Voice coil made from 180°C high temperature wire on spiral cut aluminum former
Single-piece cast aluminum frame with Alpine Patent Pending Airflow Management System for efficient cooling
Airflow Management system controls the temperature of the voice coil by directing the air across the heatsink
One sided push terminals make installation and wiring fast and simple
Each terminal accepts up to 8 AWG wire for high power signal transfer
Concealed gasket mounting system hides the screw holes and makes for a clean install
Integrated grill technology allows for a seamless installation of a grill
US Patented Compound Radius Curve (CRC) design with integrated short sleeve configuration
CRC Machined motor structure creates a symmetrical magnetic field for less distortion and improves power handling
High-power, double-stacked strontium magnet structure
Newly redesigned for a 20% depth reduction
Frequency response: 26-400 Hz
Sensitivity: 83 dB
3. Description/Condition:
This sub is in excellent shape 4 months old, only been used maybe 2-3 hours. It has a couple scuffs on the basket, nothing really noticeable and cone looked perfect when installed (I am not going to dismount from box unless I find a possible trade, then I can send you pictures of the front of the sub.)
4. What you are looking for: :
An 8" Sub (Open to any VC configuration or RMS), this sub will be in a small (.5 or less) sealed box.
5. Pictures of your item for trade:
rockford HE2 8? it has a small patched puncture hole in the cone but only cosmetic. i can throw in some 1/0 scraps and some rca jumpers and stuff like that to sweeten the deal. also a pair of 6x8 to 6.5 mdf adapters
No thanks, I think I'm going to be leaning towards cash on this one. I'm wanting a couple Sundown E8 v.2s now
That is unless I find a small 8 or two I like...I've had a couple real nice trade offers, but both fell through. Keep offering everyone, I'm not set on Sundown. I will also take some 6.5" mids plus $45 gifted.
dross93ranger
dross93ranger
Maysville, KY
dross93ranger
