alphasonik
SlammeD_SiR
buddi runnin alphasonik not sure which one, ne inputs on their amps?
i was looking at this modle right now im not sure if thats rms or max rated
ALPHAsonik PMA800DA
* 800 Watts x 1 @ 4 ohms Mono
* 1200 Watts x 1 @ 2 ohms Mono
* 1640 Watts x 1 @1 ohms Mono
* Dimensions: (W x H x L) 9 1/8" x 2 1/2" x 15 3/4"
* Bridgeable with Second Identical Model
* 3' Modular Cord Included
* Hour Meter
* Remote Mount Digital Voltmeter(included)
* Remote Mount Bass Boost Control (included)
* Heavy Duty One-piece Extruded Aluminum Heat Sink
* Beveled Clear Acrylic Protective Cover
* Tiffany-Style Input and Output RCA Jacks
* Parallel Line-out RCA Jacks
* Removable Covers Conceal Control and Terminal Panels
* MOSFET High Speed Switching Power Supply
* Internally Mounted Fan-Cooled Power Supply
* Solid Brass Nickel-plated Terminal Blocks (4-gauge Power, 8-gauge Speaker)
* THD: 0.05
* Signal-to-Noise Ratio: >100dB
* Frequency Response: 5Hz~250Hz
* Input Impedance: 10K ohms
* Input Sensitivity: 300mV~8V
* 4-Way Protection Circuitry: Thermal, Short Circuit, Overload and DC Offset
I would place Alphasonik in the same leage as HiFonics. They do near rated power from what I have seen. And are not really expensive.
I've only seen two models benched. Can't remember what they were right now. I'de have to hit up the shop.
yea my buddi was pretty much sworn by them too,
i was looking into hifonics too im not sure which one i should go with
alphasonik really hard to find on ebay
thanks guys for the responses so far, ne one else have any input on these amps ?
lol dk y u get so fustrated wit me, i kno i ask alot of questions but i just want a good system, no swapping sub/amps n stuff, got only one paycheck to blow on an amp and i did on the stupid eclipse i cant use, i dun wanan go trough another amp after thiss
i dun like buying things without reseach, took me long enuff to decide to buyun the alpine 9835 hu
and after all the reseach i was happy with the result, the only prob wit amps id understand the specs for them
just pick something already! jesus. they're all great amps. the orion/opti will do more than rated power. visoniks aren't really underrated.
but just pick which ever one is cheaper. personally, if you can afford it, get the opti. if not, get the orion.
not hard. lol.
Kicker...
Also look into Incriminator Audio....:yumyum:20.1
them things are expensive as ****.
but really, you can't go wrong with the opti d or the orion 1200d. both willl do more than rated, and are very reliable. i doubt you'll switch amps whatever you pick. the 1200d actually does closer 1400 watts if i'm not mistaken, and the opti d i kno is underrated as well. it'll do more than rated.
if you want, create a poll for the 3 amps. then go with whatever the majority chooses. that should help ya. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif ;)
SlammeD_SiR
SlammeD_SiR
Toronto, CAN
dkguitarist
