Alphasonik PMA800HCA
onoblock High Current Power Amplifier
RMS Power Rating:
800 watts x 1 chan. @ 4 ohms
1400 watts x 1 chan. @ 2 ohms
2900 watts x 1 chan. @ 1 ohm
Hour Meter
Remote Mount Digital Voltmeter Included
Bass Remote Included
Clear Acrylic ANL Fuse Holder and 200 Amp Fuse Included
Heavy Duty Heat Sink
Beveled Clear Acrylic Protective Cover
Tiffany-Style Input and Output RCA Jacks
RCA Outputs: 1 Pair
High Speed Switching Power Supply
Double-Sided Glass Epoxy Circuit Board
Variable Low-Pass Filter: 50 - 250 Hz
Variable Subsonic Filter: 15 - 60 Hz
Variable Bass Boost @ 45 Hz: 0 - 18 dB
Input Sensitivity: 200 mV - 8 V
Input Impedance: 10,000 ohms
4-Way Protection Circuitry: Thermal, Short-Circuit, Overload, and DC Offset
On-Board Hook Up Terminals
Frequency Response: 5 Hz - 50 kHz
Dimensions: 26" L x 9" W x 2-5/8" H
also n e idea what voltage this 2900 watts is claimed at
Go with the PMA1200D's...they're a whole lot more efficient if you're planning on the Alphasonik route.
You can get a lot of amps for $1000. A pair of Crossfire VR2000D's would definitely be stronger. Or 1 VR4000D would be good.
tuan
they are made by audibahn.... and they dont put out their rated power tested a few versions that supposedly put out 2kw .
yeah ive heard that before, just was wondering if they put out rated power.
sucks, o well. i guess ill have to just keep looking, lol.
tuan
ill look into that, thanks
TooLowTooGo
2Low2Go
TooLowTooGo
Jersey
jrouter76
NorthFramingham
    Jun 30, 2026
