Sold Alphasonik & Kicker Stereo Equipment
bryanmundia
For sale are a 10" Kicker Solobaric L7 dual voice coil sub and 2 alphasonik amps. One is a PMA2300A and the other is PMA4075A. The sub and PMA2300 are in excellent condition, the 4075 has a cosmetic blemish but it takes away nothing from the functionality of the amp. Here are the specs for each amp:
PMA2300A:
* 300 Watts x 2 @ 4 ohms Stereo
* 500 Watts x 2 @ 2 ohms Stereo
* 900 Watts x 1 @ 4 ohms Mono
* Dimensions: (W x H x L) 8 1/4" x 2 5/8" x 17 1/4"
* Hour Meter
* Heavy Duty One-piece Extruded Aluminum Heat Sink
* Beveled Clear Acrylic Protective Cover
* Tiffany-Style Input and Output RCA Jacks
* Parallel Line-out RCA Jacks
* MOSFET High Speed Switching Power Supply
* Milspec Double-Sided Glass Epoxy Circuit Board with Through-hole Plating
* Heavy 4 oz. Pure Copper PC Traces at All Preamp and Amplification Stages
* Solid Brass Nickel-plated Terminal Blocks (4-gauge Power, 8-gauge Speaker)
* THD: 0.05
* Signal-to-Noise Ratio: >100dB
* Frequency Response: 5Hz~50kHz
* Input Impedance:10K ohms
* Input Sensitivity: 200mV~8V
* 4-Way Protection Circuitry: Thermal, Short Circuit, Overload and DC Offset
* Thermal Cooling Fan
PMA4075:
* 75 Watts x 4 @ 4 ohms Stereo
* 120 Watts x 4 @ 2 ohms Stereo
* 230 Watts x 2 @ 4 ohms Mono
* Dimensions: (W x H x L) 8 1/4" x 2 5/8" x 21 1/4"
* Hour Meter
* THD: 0.05
I also have a custom sealed fiberglass box for the L7 for an '03 dodge ram quad cab.
The prices are the following:
Kicker Sub: $75.00
PMA2300: $175.00
PMA4075: $150.00
Box: $50.00
*Plus shipping costs
Or take the whole lot for $400
BUMP, I will guarantee this sale. I will give you any information you would like to make you feel more comfortable with the sale. Even if I need to list the items on ebay and you will purchase them through there, I am willing to do so.
bryanmundia
bryanmundia
Orange, CA
bryanmundia
