LIGHTBEING
Here's an email I got from SS:
HELLO; REGRADING YOUR QUESTION ABOUT THE VAN GOGH AMP. THIS AMP
DRAWS ALOT OF CURRENT , SO THAT IS WHY WE PUT TWO POWER INPUTS. THIS WILL
ALLOW YOU TO GIVE THE AMP ENOUGH CURRENT THAT IS NEEDED, USUALLY TWO 4ga.
POWER WIRES SHOULD BE ENOUGH. THANK YOU
I've heard some complaints from members that there XXX isn't that loud or needs to be louder. Well I have a feeling it's because you are not using both inputs. Just try it and see what happens. If you have a 2 pos distro block with one going into your sub amp and the other going into your comp amps, just reroute the other 4 gauge wire into the VGA1600. See what happens.
Think about it, even if the VGA1600 is over rated, say it's really 1450 or 1500, that should still make the XXX insanely loud in the correct enclosure.
