I'm selling an Akai MPC 1000 in excellent cosmetic and working condition. I'm asking $500 shipped. It includes original cords, 2 memory cards, maxed out ram at 128MB and a disc full of sounds. Not looking for any trades. Here are some specs and pics:
Sound Generator:
Data format: 16-bit linear WAV
Sampling rate: 44.1 kHz
Memory: 16MB standard (11.5MB sound memory), expandable to 128MB with EXM128 option
Preset sound memory: 5MB Flash
Recording time: 136 sec (16MB mono) 24m28sec (128MB mono)
Polyphony: 32-voice
Filters: 2 x 2-pole filters per voice
Filter types: Low pass, band pass, high pass
Number of active programs: 24 (with 64 pads per program)
Effects:
2 general effects: Chorus, Flanger, 4-band EQ, Bit-Grunger, Compressor, Phaser, Tremolo, Auto Pan, Reverb
Master effect: 4 band EQ, Compressor
Sequencer:
Capacity: 100,000 notes
Resolution: 96ppq
99 Sequences
64 Tracks per sequence
32 MIDI output channels (16 channels x 2 output ports)
Song mode: 20 songs, 250 steps per song
MIDI Clock Sync: Master/Slave
Drumpads:
16 velocity and pressure sensitive pads
4 pad banks
16 Levels: Velocity, Tuning, Filter Cutoff, Attack, Decay
Track Mute and Next Sequence features for live performance
Connections:
Record Input (L and R): jack x 2, balanced
Digital Input: RCA x 1, SPDIF
Stereo Output (L and R): jack x 2, unbalanced
Individual Outputs: jack x 4, unbalanced
Headphone Output: stereo jack x 1
Digital Output: RCA x 1, SPDIF
MIDI: 2 x MIDI In and 2 x MIDI Out
USB: Device connector x 1 (Mass Storage Class support)
Footswitches: jack x 2
General:
Display: 240x64 dot graphic LCD w/back light
Power: 100-240V AC, 50/60Hz
Consumption: 19W
Dimensions (H x W x D):2.97" x 12.99" x 8.985" [max 9.235"] (75.5mm x 330mm x 228.2mm [max 234.6mm])
Weight: 7.6 lbs (3.45kg)
Akai MPC1000 Music Production Center Features:
Pattern based and linear 64 track sequencer with 32 MIDI channels
32 voice drum/phrase sampler with up to 128MB RAM
Velocity and pressure sensitive pads for expressive programming
16 levels function: one sound on all pads with varied level, tuning, attack, decay or filter per pad
Two Q Link sliders for real time performance control
Built in Compact Flash drive and USB port (Mass Storage Class)
Standard WAV files samples and MIDI Files sequences
Built in Analog and Digital I/Os, headphone output and 2 x MIDI In /Out
Internal sounds in flash
4 way sample layering and velocity switching per pad
4 pole filters (two 2 pole filters) filtering for each of the 32 voices
2 onboard effects processors plus 1 main out effect processor; all which can be used simultaneously
Can resample its own output
Sound Generator:
Polyphony: 32-voice
Effects:
Sequencer:
Resolution: 96ppq
99 Sequences
Drumpads:
4 pad banks
Connections:
General:
Consumption: 19W
